No, the lines in A are much neater and straighter
A has 7 panels in series. B has 3 panels in series in parallel with another 3 panels in series in parallel with a single panel.
If Vmp is 30V then A is a single 210V string. B is trying to parallel two 90V strings with a 30V panel. That's...... sub-optimal. If you drop the single panel you'll have a 3S2P array that operates around 90V (or whatever 3x your single panel Vmp is).
Plus, if you wired everything up according to Setup B, we would mock you for the ugly rats nest of cables in all those squiggles. ?
Go to suncalc.org and see if you'll get shading then go to pv watts. gov and see what you'll produce on average.Hi
So if the 2 strings of 7 panels each is ok.
What could you do if you think you will end up with ...lets say the lh end of the strings getting progressively shaded thru out the day.?
Thanks
Richard
Hi
Hi
Yes using Paint with a shaky hand...what can I say.
So lets say we have 2 strings of 7 panels each.
Each string going in to a separate MPP Tracker.
You guys happy with this setup?
Hi
Thanks
Richard
HiNeed to know panel and MPPT specs, to see if voltage is OK.
If progressive shading can't be avoided, it is ideal to have both strings similarly shaded.
Most panels have 3 diode-bypassed sections left, middle, right. So the orientation you show would be ideal, shading one section at a time (rather than end of all three sections at once.)
Consider where shade comes from and horizon and strongest sun at noon (and any fog) to come up with best tilt and orientation. Also consider different orientations for each string.
