robby
Photon Vampire
- May 1, 2021
- 4,305
Rolling Blackouts also cause Political heads to Roll. ?Two years ago, they used rolling blackouts.
What period is the usage compared with? I think SCE is prior 3 days. So after being on inverter for 3 days the savings fade away.
Got to like $2 kWh![]()
And tomorrow looks worse.
OhmConnect has a special 3 hour long even, is giving 4x normal payback, and a $50 if you save enough. I'll hit the mark easily. I wonder if I'll make $100 again?
Hey guy, are these real temps ? Not heat index ,but actual F temps..? If it’s F then that is mindboggeling…..…My inverter is out in a shed, but was able to handle a high of 104°F today. We'll see about 114°F Monday, and 115°F Tuesday (all time record high temperature), which is forecast Tuesday.
Really .. straight out F temp…. If so that’s amazing…thx…It's 111F in my backyard right now. There's a heatwave, tomorrow looks worse.
Yea , be time to cook stuff on the picnic table and ya won’t need a grill.Be even more mind boggling if it was in C ?
Yes. Yes direct temps. I assure you it burns a bit to take a breath at 115+Really .. straight out F temp…. If so that’s amazing…thx…
That's freakin crazy…I wish you the best… I feel sorry for all the critters too..Yes. Yes direct temps. I assure you it burns a bit to take a breath at 115+
The real high today was 110°, and they are real temperatures. Supposedly hotter tomorrow.Hey guy, are these real temps ? Not heat index ,but actual F temps..? If it’s F then that is mindboggeling…..…
That’s why I asked, many news stations use heat index to jack up the news story…I have never heard of that except in some desert areas… wow… take care…The real high today was 110°, and they are real temperatures. Supposedly hotter tomorrow.
Yeow…The real high today was 110°, and they are real temperatures. Supposedly hotter tomorrow.
It was 118 at my house last year. You almost had to squint when you were outside because the hot breeze irritated the eyes.Yes. Yes direct temps. I assure you it burns a bit to take a breath at 115+
That’s awful.. put some large low profile bowls of water out at night for the critters.. there’s more roaming around than you think…It was 118 at my house last year. You almost had to squint when you were outside because the hot breeze irritated the eyes.
Optional load shed such as A/C cut was initiated for about two hours.
