Hi All. Getting the occasional over current trip from the TRACE SW 4024 inverter. Manual for it claims 33A normal with 78A peak (output) I do not think we get a draw of over 40 AMPS even with surges. Especiall with a newer low surge sump pump.
While I look for the culprit, WHICH is the 40 amperes? the 24VDC input at 40 or the output 120VAC at 40? How does that work out with ohms law? At a lower voltage (24) aren't the amps more? So if the output is say 40, is that like 90 amps DC on the input side or more like 15 ?
