Ah. I see. Not connected. While the manual notes this exists it doesn’t mention anything about connecting.The renogy charger has sense leads designated bvs.
If they are connected remove them.
Suggest op try another charge profile with lower voltage.Could it be that the Renogy is targetting a higher voltage than spec'd? I have a memory of that being mentioned
How high did the highest cell get?I just ran a test.
Results and observations:
- set the BMS cell over voltage higher so I was pretty sure it wouldn't trip
- put my multi-meter on the battery
- started the van to charge and monitored both BMS and multi-meter
Unfortunately the Renogy unit doesn't let me change voltage separatly. I could use the charge profile for a Gel battery which is 14.20 but not sure about the wisdom of doing that. Maybe my BMS is just reading too high?
- charging continued at 300-400 watts until my multi meter read 14.38 where it started tapering off quickly. Charging went to zero when meter read 14.42 (BMS read 14.39).
- BMS consistently read .03 volts higher than my meter.
I agree with @smoothJoey on this one. I think those two cells have slightly more energy in them, or a slightly smaller capacity, than the other ones. I do not think this is a serious problem though. If you wanted you could bleed some energy out of one of these manually with a resistor or some other load just to see what happens. Again this is not pack threatning but you could be losing more than a few Amp hours per cell on the lower ones since they do not get fully charged.I have a similar situation on my new LifePO4 16S battery bank. I'm using the aluminum cased cells from China with an ANT BMS.
If you have a cell or cells which go higher and reach the cell protection cutoff voltage, it will open the circuit and stop the charger. This can happen when the total voltage of the pack is still somewhat below the bulk charging voltage.
Typically, this happens when you have a cell(s) that has a higher voltage than the others as you near the end of the charge. The charge power can still be a few hundred watts because the overall battery pack voltage is just low enough that it is tapering down but still being charged at a moderate rate.
In my case, I have perfectly balanced cells until I reach a nearly charged state (just under 54 volts). At that point I have two cells which will shoot up in voltage faster than the others. One of those cells can hit 3.6 v/cell and trigger the BMS overvoltage protection, while most of the others are still around 3.35. This "imbalance" only exists at a very high state of charge. When the charger stops at night, the BMS balancer will bring the high cells down to 3.35 to match the others, but the next morning when the charger turns on again to try to "top off" the charge to 54 volts total, those same two cells will shoot higher.
This does not seem to be a faulty cell / internal resistance problem. Under load all the cells seem to stay well balanced - none of the cells are sagging on discharge. I have tried lowering the bulk charge and float charge voltages slightly and it does seem to help a little, but the pack still always suddenly goes out of balance as full SOC is approached. I have come to the conclusion that those two cells have a differently shaped "knee" at the top end of the charge curve.
You could try thisThe same thing happens now with the BMS balancer connected. The balancer will kick in to equalize the cell voltages perfectly after the charger turns off when the sun goes down.
You keep mentioning to only balance during charge. But why wouldn't you balance in storage as well. If you dont balance in storage the cells will stop being balanced when charge shuts off due to over voltage.You could try this
If your bms has the option, set it to only balance during charge and only balance at 3.4 volts per cell and above.
If that doesn't start the cells converging after a few cycles then decrease the charge current so they stay charging longer.
If that still doesn't start them converging adjust the tail current down to keep them even longer at the top.
You don't want to do that forever though so when they sufficiently converge at full charge you can revert the changes.
I would still leave the pack so that it only balances during charge though.
The voltage with wich to start balancing is also tricky. I think it may need to be adjusted if you look down at 3.4 and he wrong cells are too high. Not saying it is a bad number just to verify it is not too low.
That is a fair point Im just thinking that shutting down balancing as soon as charging stops will make balancing take forever. I guess it would also depend on where your resume charging set point is. Do you cut off charging at 3.65 and resume when cells drop to 3.4 or do you resume at 3.5.My idea is to get the cells to converge at a single point.
If the battery is charged to 3.65 volts per cell that is where the cells should be synchronized in my opinion.
If the balancer is still working when their is no charge current or when float voltage is present then the batteries will balance at full resting and/or float voltage which means they will be potentially less syncronized at 3.65 volts per cell.
Yes that number is a bit of a guesstimate based on the idea of converging on a single point.
That is the best scenerio. It is less common in the solar charging environment because the goal is often to get the most solar energy from the sun into the cells.Some inverters communicate with BMS and adjust their charge settings accordingly.
