Is it OK to vertically stack prismatic cells side by side?
s0larcuriosity
India
Both EEL and Seplos sell 48v battery boxes that stack cells by their sides in two columns with 8 cells in each column. Is it OK to stack batteries like this especially since the last ones bear the whole weight?
EEL_48V_16S_DIY_Battery_Box_Kits_Built_in_200A_BMS_with_Wheels_suit_for_230_280_302Ah_cells__1...png
The YIYEN 7.5kwh (2P16S) wall mounted battery installed in 2018 is arranged in a similar manner as your pic, 2 rows stacked but with the terminals & bus bar connections facing each other. Working just fine so far.
Many manufacturers are using this setup, more and more.
Still there is some debate about this position; especially wrt electrolyte not covering all necessary parts over time.
I wanted this setup at my build as well, but because of the debate about the position of the cells, decided not to go this route.
I did it two years ago and got some electrolyte leakage. Not much damage but when I added 16 more cells I changed to horizontal configuration.
