I am going to have to look this up. I only know one type of device, one that makes sure that gets hit if a lightning is going to hit your house.is it an arrestor or an attractor? That is the question. I would place it 50+ feet away and up higher with plenty of grounding and path.
Thank you very much. My house is going to look like some kind of neo-cathedral. I am not going to connect it to the electrical or solar ground, is going to get connected by itself directly to the ground.Improved version. Don't connect it to your electrical or solar ground.
I am trying to understand what 'do it correctly' is hereIf you intend to install any type of lighting protection. Please do it correctly. Or you are wasting your time and money. And bring your checkbook. It will be expensive.
It's been awhile since I installed one. And am hesitant to provide detailed instructions.I am trying to understand what 'do it correctly' is here
let us know what you findI am going to have to look this up. I only know one type of device, one that makes sure that gets hit if a lightning is going to hit your house.
Same here.I've been following this family for a couple of years and this guy is a competent, experience, Victron oriented, DIY solar opoperator.
The system in the youtube isn't mobile, it's a fixed array and solar shed. He did have a grounding rod/conductor at the shed end but he also said he thought it was inadequate and expanded the grounding at the shed side in the youtube as part of beefing up his protection for the future.Same here.
But he didn't know anything, when he installed his big (for him) system.
I started following this family. When the other family (Beginning from this Morning), came to help him install the system. Their system is mobile, so that's why the grounding conductor was missed. And SPD's were just a guess on their part. Mostly because they just happened to be included in the combiner boxes they purchased.
Begs the question, would it be better to insulate from the earth as apposed to creating a path(ground your gear to earth) for lightning to connect?Lightning protection is more an effort to protect than a guaranty. And it really depends on your setting. I live in what I would call a mini holler. A small opening in a valley of trees. The trees around me are far more likely to get hit than my house. Now, if you are out in the open flatlands, you have a different story.
Direct strikes probably nothing will help. Induced gradient however is energy that is the result of a nearby strike in wires or other metallic objects. The energy has to be dissipated to earth. Not creating an intentional path just means the energy travels every path it can find until it gets dissipated to earth.Begs the question, would it be better to insulate from the earth as apposed to creating a path(ground your gear to earth) for lightning to connect?
They say if your in the mountains, say hiking, and your hair starts to stand strait up, that you should stand on your pack and squat down making your self as low as possible while insulating your feet as far from the ground as possible. It reminds me of that famous photo of the early stages of a strike where there where these tiny leader strikes coming off of points of trees and corners of a house all pointing towards the bolt. The one that connects first gets the bulk of the strike. Just some thoughts to add.Direct strikes probably nothing will help. Induced gradient however is energy that is the result of a nearby strike in wires or other metallic objects. The energy has to be dissipated to earth. Not creating an intentional path just means the energy travels every path it can find until it gets dissipated to earth.
That can be thru your wiring in your house, the inverters, PV array, basically any conductor. Creating an intentional path to earth is lower impedance and the energy will follow that path and dissapate the energy.
Yes I know. But the guy who showed him how to set it up. Only has a mobile system. So, he didn't know anything about grounding and SPD'S.The system in the youtube isn't mobile, it's a fixed array and solar shed.
It definitely is. I have been preaching this to anyone who would listen.It seems like this issue of long underground wiring + ground strike could be true
Anything outside with substantial length. Overhead or underground. (Overhead is more susceptible)but then I wonder at the details such as wire length, depth, does conduit help? For example, my runs from the Array (with surge protection) to the house are <50ft in conduit (one underground, the other along side the house wall) but then there's another 100ft within the house itself - so 50ft outside + 100ft inside.
If you have a high lightning hazard then mount a steel pipe in a suitable poured concrete footing and connect an air terminal to it, located ~8-10' north of the array and 4-5' higher. Run a couple ground rods from the pipe about 10' or more away-- and away from any of your equipment and the house. Don't connect anything else to it. If you want to you can put a plastic pipe around the steel pipe and down-conductor to reduce the risk of flash-over to your array somewhat.Begs the question, would it be better to insulate from the earth as apposed to creating a path(ground your gear to earth) for lightning to connect?
Well, i just want to protect my panels and all, they are on the roof and they are grounded so i thinks is risky to have them just like that.Security cameras where I used to work captured a lightning strike on one of the other buildings. It was a large campus with dozens of industrial buildings, the one that got hit was the only one protected by a special lightning protection system installed by a company that does that kind of thing. The strike hit one of the rods on the roof, went down the side and turned a telephone pole into a million toothpicks, arced over to the communications raceway and incinerated that, arced over to the conduit carrying the 3 phase into the building and melted that, then blew everything in site off the side of the building. In the 60 years the place has been there, no other building has ever been hit or damaged, only the one that got the expensive protection. So based on this rigorous statistical analysis of a sample size of one, if i were in your shoes, I'd spend a more money on insurance and forget the whole lightning thing.
i have 6 of these installed, one per each panel strings. A SPD is a different thing?FWIW: I've installed several hundred solar arrays over the last 30+ years and AFAIK none of them have ever suffered any lightning damage. Ground mount, roof mount, mobile stuff for FEMA, single and dual axis trackers, etc you name it. Anywhere from a hundred watts to a few hundred KW and no solar panel have been damaged by lightning.
My 2 cents is that you're wasting your money trying to protect the panels from lightning.
However a surge induced on your system from from nearby strike is a real thing. MidNite's SPD are top notch for that.
