Sorry I didn’t read you’re question correct the fist time. So the correct reply is: I want the inverter to 1.switch off completely when it’s idle and the batteries are lowSo are you looking to turn inverter off at a certain time or times or remotely or if there is no load on the inverter.
2.turn on again when the batteries reach a certain “higher voltage” (the inverter would not have any load on it when step 1and 2 occurs).
My batteriepack is 7x2.65-4.0v 40ah lion + 7s lipo “blocks”~40 ah in parallel. I’m planing to build 7s pack out of my 1000x18650 pre used Panasonic ~1400-2000 mah.
Thanks
