Is this the best way to add more PV to my system?
pvdude
Florida
Wife & I finished placing the 12 PV panels today!
Next week I’ll go pick up the batteries, and we can turn this thing on for the first time.
There is room for 4 more panels on the frame, so we could do 16.
Is the following the correct way to proceed to add 4 more REC 365AA?
Currently have 12 panels in series, about 524vdc @ 9.5A
The charge controller is a Schneider Conext MPPT 100A 600VDC.
It operates from 230 to 550vdc.
So I can’t put any more in series, or voltage will be too high for the CC.
Adding 4 panels, I could split into two strings of 8 series.
That would provide two series strings of 352vdc, 19A, connected in parallel.
5840 watts.
Is this the best way to use 16 of these panels?
Thanks,
pvdude
I don't see any other way - But your 200 feet of #10 feed wire would probably need to be upgraded to #8 or maybe even larger wire
Don
Thanks, good point about the cable.
I ran 4 #10 in the conduit, onlu used two for the existing connection.
Could double up w/ the spares.
Not sure what AWG number two #10 connected together would yield.
Sure - #10 seems to be adequate for 9.5 amps with your string of 12 panels, so adding four more and doubling the current would also be fine with another pair of #10 feed wires - Just paralleling a pair of #10's effectively equals a #7 wire
Don
352Voc
19A
200 feet one way
Is 2.16% voltage drop on 10AWG
Click on link to see results and change inputs.
That drops to about 1% with a #7 cable
Calculator has a double cable input.
Using two 10 AWG is 1.08% voltage drop.
352Voc
19A
200 feet one way.
1.08% is exactly the same number it gives for a #7 wire - Which I guess confirms that a pair of #10's paralleled does equal a single #7
Don
5840 watts.
Thanks,
pvdude
How cold does it get at your location?
Temps lower than 77°F raise the Voc.
528V x 1.1 temp compensation for about 32°F is 580V which is well over the 550V limit.
Thanks for all the tips, links and comments!
Yes, it does get to 32 degrees here once or twice a year, just before sunrise.
I had thought to simply disconnect the PV array on those nights.
But at my age, I have about 3 functioning brain cells remaining, and two of them are always
looking for where I left my glasses.
So I would forget to disconnect and the CC would not like it.
Seems like the most simple and expedient solution is to add 4 panels, configure two series strings of 8, and parallel those.
It occurred to me that I can just treat each string as an independent 8S, thus only putting about 350vdc @ 9A on each pair of #10 wires.
I can combine them at the charge controller, instead of the Midnite solar, to obtain parallel.
Just have to split the connections in the midnite solar combiner (un-combiner, in this case), add another SPD 600, done.
Don
You can mostly consider the calculation between single wires and multiple as a function of their total cross sectional area.
so a single #10awg = 5.26mm^2 *2 = 10.5 which happens to be almost the same as the 10.6 of a #7 awg.
