Ryushin
I thought my setup with a photo diary might help others. I passed my Electrical Final inspection yesterday, now I'm just waiting for PTO.
First let me give thanks to the following people and companies:
@Will Prowse for creating his Youtube channel and this forum and selflessly helping others with DIY Solar.
@HighTechLab / AKA Dexter for helping me with questions and parts and for providing the Sol-Ark 15K and SOK batteries.
@Danke for helping me in the very beginning with sourcing parts and getting me going down the right path.
Sol-Ark and Growatt for their support staff working together to get the two Growatt Inverters working with AC Coupling to the Sol-Ark 15K.
Greenlancer for turning my rough plans into professional documents I could submit to my building department and utility for interconnection. They also went above and beyond to modify the plans as changes were needed and were always prompt, professional, and courteous. I cannot recommend them enough!
So I've been wanting to do solar for the last three years or so. But the CFO, AKA, the Wife did not want to at the time. Early this spring she gave me the go ahead and I blew it by going 40% over my estimate. The "little" stuff ends up being very expensive and electrical components are just stupid expensive. Either way, it's done now and I think she will be more approving once we start seeing a ROI and the 30% back from the government. I spent the April through mid June coming up with my plans and gave those to Greenlancer to complete. Two days later I had my plans and I submitted them to my AHJ and my electrical utility CORE for Interconnection. My AHJ approved my plans July 2nd I started ordering parts the following day.
Four months later, I'm done. Photo Diary: https://cloud.chrisdos.com/s/rAxMbpbDgCY6i6D
There were some stories along the way. Especially the rush to get the grid connected last weekend when 10" of snow arrived and covered the panels. I did every single bit of the install myself. Including wiring the new 200A Load Center.
I also don't know if my 4-Ton AC Rheem comes with a soft start or not. I did not need to install one and the AC will come on fine with just a flicker of light even if the double oven AND electric dryer is running. Very impressed with the Sol-Ark 15K. Didn't miss a beat even with my air compressor or big miter saw. Have not been able to over load the Sol-Ark 15K yet. It is bloody impressive!
Parts and Sources:
Parts and Sources:
- Sol-Ark 15K: https://www.currentconnected.com/product/sol-ark-15k-all-in-one-hybrid-inverter/
- HomeGrid BusBar for Sol-Ark SA-15K: https://www.solar-electric.com/homegrid-hg-sol-ark-15k-busbar-pair.html
- Two Growatt MIN 10000TL-XH-US Grid Tie Inverters for AC Coupling to the Sol-Ark: https://signaturesolar.com/growatt-10kw-grid-tie-inverter-min10000tl-xh-us/
- Bluesun 37 460W Bi-Facial Panels and 30 550W Bi-Facial Panels (13 strings): Ordered directly from Bluesun. Message me for contact information.
- IronRidge Racking Using HUG Mounts: Greentech. Many locations around the country. I used the Denver location.
- 8 SOK 48V Batteries: https://www.currentconnected.com/product/sk48v100-48v-server-rack-battery/
- 55U 20" Deep Server Rack: https://www.racksolutions.com/server-racks/server-racks-cabinets-enclosures.html (Bought from PC Nation)
- CyberPower 4 Post Rail Kit for batteries (supports 231 lbs): https://www.amazon.com/CyberPower-4POSTRAIL-4-Post-Universal-Mount/dp/B00TCELZTK
- Hoffman NEMA 1 Hinged 12"x12" 4' and 3' Wireways combined for 7': Part #s: F1212G48H (48"), F1212G36H (36"), F1212GCPNK End Caps x2, F1212GCPNK U-Connector. Ordered from Quotebeam. Best price I could find.
- Austin NEMA 3R 8"x8"x6' Wire Trough: https://www.cityelectricsupply.com/austin-enclosures-ab-8872rtg-8x8x72-raintight-trough
- GE 200 Amp 240-Volt Non-Fused Manual Power Transfer Switch: https://www.homedepot.com/p/GE-200-...ency-Power-Transfer-Switch-TC10324R/100150463
- GE PowerMark Plus Outdoor 125 Amp 4-Space/8-Circuit Load Center For Growatt Inverters: https://www.homedepot.com/p/GE-Powe...-Lug-Circuit-Breaker-Panel-TL412R1P/100123400
- Square D QO 200 Amp 2-Pole Outdoor Circuit Breaker Enclosure with QOM2200VH Breaker: https://www.homedepot.com/p/Square-...with-QOM2200VH-Breaker-QOM2E2200NRB/100210055
- 2 x Siemens 200 Amp 4-Jaw No Bypass Ringless Meter Socket: https://www.homedepot.com/p/Siemens...ss-Steel-Latch-and-Hasp-SUAT417-XGF/100181685
- Siemens 200 Amp 2-Pole 3-Wire General Duty Fused Outdoor AC Disconnect: https://www.homedepot.com/p/Siemens...-General-Duty-Fused-Outdoor-GF224NR/302352591
- Bussmann NON-200 One-Time 200-Amp Low-Voltage 250V, K5 Cartridge Fuse: https://www.amazon.com/gp/product/B000LES9MQ
- Square D Homeline 200 Amp 40-Space 80-Circuit Main Breaker Qwik-Grip Plug On Neutral Load Center: https://www.homedepot.com/p/Square-...s-Cover-Value-Pack-HOM4080M200PQCVP/301278214
- Ferraz Shawmut Power Distribution Block #MPDB69123: https://www.factorymation.com/MPDB69123
- 3 x Ferraz Shawmut Polycarbonate safety covers #MPDBC6869: https://www.factorymation.com/MPDBC6869
- Blue Sea 5502 Fuse Block Class T 225-400 Amp: https://www.amazon.com/gp/product/B011KL5HFA/
- South Bend Components 350A Class T Fast Blow Fuse (2-Pack): https://www.amazon.com/gp/product/B0BFRSCVS9
- OELFFOW IP67 Button Switch Outdoor Waterproof Box Red Button Emergency Stop with Protective Cover: https://www.amazon.com/dp/B0BL34P2NT/
- EMT Conduit and lots of wire. Lots and lots of wire... Bloody Expensive wire!
- Heated Seed Mats and Temperature Controller to Keep the Batteries Warm: https://www.amazon.com/dp/B08NB4PX9Y and https://www.amazon.com/dp/B01I15S6OM
- Firman Tri-Fuel Generator: https://www.costco.com/firman-7500w-running--9400w-peak-tri-fuel-generator.product.100840185.html
- EG4 Chargeverter: https://www.currentconnected.com/product/eg4-chargeverter-48v-100a-battery-charger-240-120v-input/
