and one cell certainly is. What would make the amp count so far off?Whenever any of the cell over-voltage protection the bms thinks the battery is full..
8, 302A cells in 2, 12v batteries, each with a JBD BMS. This configuration is the only way they'd fit in the boat.What ah capacity of your bank?
yes but at 13.34V?on the app it say 13%.
300*13%=39ah
app say 37.76 so 39 is close enough.
what seem to be the problem?
Thanks again BB, I set full cell V to 3.650 and now both BMSs are reading 90%. Cheers!I think the 3 key settings here are the cell full voltage, cell over voltage, and the cell 100% cap voltage.
When BMS is tracking via voltage, it will thing the battery is 100% capacity when the voltage is at 3.38 volts.
It won't reset the BMS to start tracking via amps in and amps out til you have reached the cell full voltage ... which is set at 3.65 volts. Since the cell over voltage is also set at 3.65 volts ... if you a cell ever reaches the full threshold, the over voltage will also triggered.
I would have the cell full voltage and the cell 100% Cap voltage set the same .... 3.38 seems a little low for the for the 100% cap voltage, but will probably work correctly if you set the cell full voltage the same ... and leave the over voltage set to 3.65.
Once you reach the cell full voltage, it should ignore those xx% Cap Voltage settings and start tracking amps.
I thought it already was at 3.65 .... Weren't you going to make it the same as the 100% cap voltage?Thanks again BB, I set full cell V to 3.650 and now both BMSs are reading 90%. Cheers!
Balancing at too low of a voltage can easily make the pack MORE imbalancedThey were charged and discharged to this yesterday.
Balance is set low b/c cell #2 jumps to 3.65v and triggers the BMS.
