Dear all,
This is the second JBD BMS I install. First one worked fine for 2 years until serial port failed. Now the new JBD-AP21S002 works fine for everything except the amps/power readout. The sense cable is on the C-terminal (load/charger) and the board resistor 20W10RJ reads 10ohm. Any idea what i did wrong or what i can do more?
Picture attached is when charging at 80Amps (read from victron UI). Power and amps are always zero, no matter of the (dis)charge power. Don't mind the Ah; it was not set yet to the actual 560Ah @ 24V.
kind regards,
Frederic
kind regards,
Frederic
