I just received my new JBD BMS 300amp. I was going to go with a Daly pretty straight forward and had instructions plus I have used them in the past.
After reviews I thought I would try the JBD.
I understood no instructions from posts here.
Where I'm lost is the wiring, I have found diagram but wire colors are different so how does this get wired up.
I posted pic of my 2 harnesses along with the BMS.
first harness (large) is pretty straight forwardand .
I'm lost on the second with the colored wires does the black go to a neg somewhere?
Orange go some where?
then do leads 16-19 connect to positive or get cut off?
This set up is going in a golf cart 48volt 105hr 3C batteries.
Thank you in advance
