jbd bms for lifepo4 (with bluetooth) - 16s 48v 200a
Matthew 2
jbd bms lifepo4 (with Bluetooth) - 16s 48v 200a) i have my 24v battery pack built and bms instilled with cell wiring mod main is that xiaoxiang app will not let me change battery pack voltage low and high set points on the bms you can change them but it retunes to default i.e. 48v 16s set points
Fixed two wires in wrong place JBD need to fix the wiring diagrams for uk and US market hard to read
two wires in wrong place JBD smart bms sensing 16s battery config i.e. 48v not 8s 24v :) frog star drift app work with this BMS
I have a similar bms and also have lifepo4 280ah 16 batteries, I'm quite confused how to wire the bms do you mind sharing? My bms is JBD-AP20S003S
This is the bms and wires..
Start with both harnesses unplugged.
The black wire on the bigger harness goes to negative on cell one. Next, attach the rest of the wires on that connector to positive posts on cells in order. You should end with the red wire on positive of cell 13.
Now, the two red wires on the small harness goes to positive of cell 16, the next yellow goes to positive of cell 15, and the rest of the wires (including the other yellow, three whites, and a black) on the small harness all go to positive of cell 14.
Now plug in the big harness, then the small harness.
Thanks I'm super grateful for your clear directions it has been super helpful.. combining it with this diagram which I found here has led to success thank you...
diagram sourced from https://diysolarforum.com/threads/jbd-7s-20s-balance-leads-wiring.38111/#post-482316
