SupraSPL
- Aug 28, 2022
- 226
When Charge Balance is turned OFF, the BMS will still passive balance the high cells when:
-Cell is above 3.4V
-Difference between cells is more than 0.015V
-Battery is not discharging
-Battery is not charging
Balancing above 3.4V makes sense because above that, the cells start to increase voltage rapidly, which reveals the imbalance and let's the BMS work on it (albeit very slowly). When resting, the cells will fall below 3.4V, which will stop the balancing eventually. If you still need more balancing after this (could take a day) then you can charge back up to 3.5 or 3.6V and let it balance again.
You can do some decent maintenance top balancing this way and you can even tighten them up to .005V instead of .015V in the settings.
Once that is done it probably makes sense change it back to Charge Balance ON, so you get a small amount of balancing on a regular basis during regular use.
-Cell is above 3.4V
