heavy-impact
- Apr 28, 2020
- 72
I'm repowering a Ford Neighbor Think golf cart from 72v lead acid to 20S li-ion using new Samsung 64ah prismatic cells. I couldn't find a good BMS in stock here in the USA so I ordered this one from ali https://www.aliexpress.com/item/3256806124920304.html It's a 300amp JBD relay type. Is this a good BMS for my application? I've been told the cart draws about 125a on full throttle start. I also have a 5a active equalizer board. Should I run it on the pack also or will the BMS be sufficient?
Thanks
Thanks
