meetyg
- Jun 4, 2021
- 1,101
I have the 200A JKBMS for 8S Lifepo.
When connecting to the cells, I was wondering how much current one terminal (on each side) could handle?
My dilemma is if I should use both terminals on each side with 6 AWG wire each, or if I can get away with using just one terminal with a 4 AWG ?
I know that double 6 AWG should handle more current, but it makes the cabling more cumbersome (either use two lugs on the cell, or one large lug with two wires).
The single 4 AWG would be alot more elegant and simple.
How much current would you rate each option at (using 200C rated silicone insulated wire) ?
While I don't plan to push it, I would like to be able to pull around 100A from the cells (105Ah cells) if needed.
I mentioned these wire sizes as this is what I have at hand.
Thanks.
Thanks.
