hardtop
I'd like to connect my BMS, but there doesn't seem to be a manual for the device and I'm new. Its the JK BMS 4-8S (12V-24V) - 200A Continuous - 350A Peak - 2A Active Balancing - JK-B2A8S20P
It can't be that hard, but I don't read Chinese and I don't know the BMS connections.
- There is a B- and a P- connection for power on the BMS, which is positive and which is negative?
- For red sensor lines, do I connect one to each negative terminal of each cell?
- Should I connect the charger to the BMS B- and P- connections and the inverter to the pos and neg connections of the pack?
