Hynek
I'll try and keep this short and sweet so please bare with me.
I finally ditch the lead/acid and upgrade to a 48v16s lifepo4 system with JK B2A24S20P, batteries are EVE 280K. Everything works great, cannot be happier
The neighbors looking to upgrade as well, buy exact same batteries and bms. This one is connected as a 24v16s system, figured on using same bms because they can add another 8 cells in parallel later if they need some more capacity.
I connect BMS and this unit is only seeing 8 of the 16 cells, 1-8 no 9-16. Will not allow charge or discharge to turn on. Thinking maybe bms is defective, I swap it out with mine and it works just fine, sees all 16 cells right away. I try to rearrange the order of leads with not avail. No idea on what to try next
I'm thinking its possible that the JK B2A24S20P does not work with a battery in parallel. But can't figure any reason why it wouldn't. If anyone has any info or things to try please let me know. I'm at a dead end
Thanks in advance
Thanks in advance
