Was wondering if anyone could help with setting up the connection from a JK BMS to a Sterling 30amp B2B charger as I'm unsure of exactly which wire needs to be used in which connection.
I assume I will need to remove the wires from the standard power button that comes with the JK BMS and attach one of the wires to the correct B2B connection so the B2B can re-wake the BMS after low voltage or other scenarios where the B2B needs instruction to start/stop. I have attached the instructions from the B2B charger where it describes the two BMS connections available. Does anyone know which wire from the JK BMS suits one of the connections described below?
I'm quite new to this so I'm only assuming the BMS power button wiring is used because the B2B charger doesn't have CAN communication, it's far simpler, at least it appears that way. Really appreciate any help thanks for reading.
