JuncTek Battery Monitor vs Victron SmartShunt
A likely false positive from Clam or MaxSecure checking an Android .apk file does not make me sweat.
Possibly. Also Norton Secureweb flags the URL as malware. Not sure if that's simply because it's an IP address, or additional criteria. Coupled with the higher than I'd like power use (30mA screen off, 70mA screen on), it's more trouble than it's worth. I'm going to send it back where it came from. I shoulda just paid up for a Victron SmartShunt.
I have both the Junctek and a 500A Victron SmartShunt installed in series. A dedicated wall mounted android phone displays Victron and Junctek data.
Both always agree within 1% V&A and 1-2% SOC.
Most of my gear is Victron but I must admit to preferring the Junctek display for everyday use.
I agree that a dedidcated display is nice. Phones are notorious about acting up... and they're slow to connect up too. Of course they too burn up a lot of power if used as always on displays.
Do you have the junctek latest shunt the H series ? It doesn’t have the amp hour used data . I wonder if there is an option to show that in the display
The display is not really configurable but it displays all the information I require for day-to-day use.
It also stores data but the Victron SmartShunt wins for historic data retrieval.
Total Ah ever used? No.
Ah used? Both the head unit and app display show Ah remaining.
My battery capacity is set at 560Ah. The maths is easy.
App screeshot a few minutes ago.
Click to enlarge.
I swapped from Chinese inverters/mppt six month ago for a victron system (had enough of those unefficient, noisy, unreliable chinese inverters), i now have one MPII 3kVA, one MPII 5kVA and an RS450/100 and i go to say i've still not bought a BMV 712, not about the price but the Junctek display is far better and the system is pretty good to evaluate the remaining capacity. I'm trying to implement an interface between Junctek shunt and the cerbo.
1. The 4P flat cable between the measurement module and the shunt cannot be extended, and the data cable between the display and the measurement module can be extended to 30 meters at most;
2. It can be used without temperature sensor, and other functions will not be affected except that the temperature cannot be displayed;
@Rickey , I have some questions, I hope you can help answer them:
1) what is the reason the 4 core cable between the shunt and main unit cannot be extended longer than the supplied 175mm cable length? This is really inconvenient in a real world installation environment where in many cases a location suitable for the main unit directly next to the shunt may not be available due to other pre-existing cabling and devices being in the same area.
2) Is the Bluetooth access point on KH160F within the main unit or the display unit?
3) Can more than one display be connected to a single main unit?
Deleted. Questions not directed at me.
You or anyone else are welcome to answer. I directed my comment to Rickey as I was quoting his post and I think it’s an open secret he’s the developer of the product, but has hasn’t posted on this forum in a long time and I’m not precious about where I get my help from ?
2. The Bluetooth module is located in the main module mounted near the shunt unit. It all still performs fine without the display via the app.
3. Untested but I had no success with the previous Juntek wireless model.
We use an old phone permanently mounted up front in our motorhome to display the Junctek data simultaneously, Victron gear data, navigation etc.
Thanks @scubadoo and Happy New Year to you (just turned midnight here!)
Am I right in thinking the connectivity is strictly Bluetooth only and no option to get it onto wifi so the data is available over the internet when you’re not in close proximity to your battery?
Unfortunately no WiFi involved but I have followed a few clever users of the previous KGxxx models who have persevered with output protocol details and achieved some amazing results.
e.g.
and a few YouTube detailed videos also exist.
Not above my knowledge level but it appears to be a lot of work for not much gain.
A happy new year to you too.
Almost lunch time on new years day here.
Thanks @scubadoo, good to see people are figuring out the comms and sharing info openly. It’s a bit beyond me honestly, but maybe someone one day will make a really simple how-to guide on getting a Junctek networked.
It would be cool if Junctek could in the future release a wifi module which plugs straight into the RS485 on the main unit and would allow the monitoring app to be used when you’re away from home, or simply out of range of the bluetooth connection, like on the other side of the house from the battery. I’m sure that would be a popular upgrade for existing users and they would sell well.
FWIW, I use a cheap prepaid cell phone (without a SIM card) to monitor all of my BT solar stuff. Then I remote into that phone via wifi with my PC or working cell phone. Not the most elegant solution, but it works fine. I also have a couple of Blink cameras I use to see the displays on equipment too.
I can't speak for the Victron, but I have a couple of the Junctek units (including the most recent version) and find the "accuracy" more than adequate. Then again, I rarely go more than a few days without fully charging my batteries.
The Junctek battery monitor is easily A & V calibrated via their app in 1% steps.
After slight tweaking both my Junctek and Victron SmartShunt agree within 0.01V, 0.02A and 1 or occasionally 2% SOC across the entire usual battery levels.
Does anyone else have trouble with the mobile app disconnecting and not reconnecting via Bluetooth unless you quit the app and reload it? This is on iOS 16.7 but possibly the same on other platforms too?
Has anyone found a solution or workaround to this, or is it a case of quit and reload app every single time you want to use it?
With the Android app, I find that it does not stay connected for a long time (I am using a non-active cell phone for monitoring all of my BT solar devices). I had also found that sometimes, even clicking the "search" button to reconnect does not work and it requires rebooting the Juntek device (I think the device thinks it's still connected when it's not). However, I found that if I just close the app every time I am done looking at it, it always reconnects fine the next time I open the app. I do have the iOS app to, but I rarely use it and always close the app anyway when I'm done.
The Bluetooth device of KH160F is located in the host computer, and one host computer can connect up to 2 monitors.
It is expected that a coulomb counter with wifi function will be launched by May 2021
How can a user buy a second monitor display for KH series? I looked at all listings on AliExpress “Junctek factory store” but didn’t find any listing which was display only?
I guess you mean May 2024? I hope you offer it for sale as host computer unit only, so users who already bought a battery monitor and have a shunt and display unit can upgrade their system just by buying the new wifi main unit.
I’m still curious about how a second display may be added to the KH160F. I see on the main unit “RS-485 display“ and “RS-485 link” connectors. Is it enough to just buy a second display and connect to “RS-485 link” on the main unit, or is some setup required?
@Rickey can you please confirm connections, setup and how to buy second display?
