WoodsieLord
Hello there,
I'm trying to make a simple kettle heater of sorts. That is, a somewhat heavy, flat base with the coil, that get's hot so you rest a kettle on top.
I'm bad at describing things and I don't speak english as I would like.
I never used kanthal before and I'm not exactly sure how to use the online calculators at all. I found out today that "vapers" use this wire so I think the calculators I found are related to that purpose.
I made the base on clay (soon to be cooked) at a pottery workshop and I was advised to get 1mm kanthal wire for my "home-brewed coil". I already got 10m kanthal wire A1, 1mm think, round. It was actually pretty affordable, thankfully.
I don't know how many Ohms should I go for. I know the size of the coil (more or less) as I know the cavity's dimensions (more or less). But I don't know if I should be considering how many turns should I do?
The only thing I tried was measuring continuity with my multimeter and it seems shorted out. Never used kanthal before. Don't know what I was expecting but I thought it would be highly resistant.
This is the base I'm making in clay. I thought of a single coil that would fit the space.
Any clues you can give me ?
Thanks in advance!
EDIT: Forgot to mention that I would prefer to use it with mains ( 230V AC ). And that I don't want to put a kettle on top, so I don't want the coil to be able to boil the hell out of the water ASAP. On the contrary I would like the coil to bring the them up more gently than a kettle
Thanks in advance!
