Apparently your application and Prime allow parallel batteries and daisy chained communications.
Right now I'm using SBS, which has three separate battery power and data ports. Haven't seen mention of parallel.
The manual for your, linked above by
![Sun with face :sun_with_face: 🌞](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f31e.png)
, details switch settings in "3.3.1 Cable Configuration"
It shows Section C dip switch settings for primary vs. secondary battery.
It shows Section B terminating resistor, but not how to set.
"7.1.1 settings for communicating terminating resistor"
I am having trouble following their words and diagrams.
They say, "middle side", maybe that means a battery in the middle of a daisy-chain bus.
They show resistor enabled for Primary, not for Secondary. I expect that only if Primary is last battery in the bus. If you buy one battery then add another, I'd think Secondary might end up being the last.
"daisy chained from the secondary to the primary" sounds like what they say.
I think the communication wires should daisy chain, with minimal if any stub (like < 1"). For my Sunny Boys, I insert the ends of two LAN cable into the same screw terminal.
I think resistors should be enabled by DIP switch at the end(s) of the bus.
For you, I think Primary Section C gets both switches up, Secondary gets left switch up, right switch down.
For section B, I think Primary gets both switches DOWN (on), secondary gets both UP (off)
![1717346288341.png 1717346288341.png](https://diysolarforum.com/data/attachments/219/219209-6023c85b4800f9775d927362461a19e2.jpg)
