Gphoto125
I purchased a lifepo4 110ah Litime w/bms and cold temp shutoff battery to replace my tired agm 41/2 year old battery for a small camper, which was connected to 1-100w panel and a pwm 20a controller. I thought the 100w panel would only just take longer to charge the new battery, instead I am told I should have 300w of panels to charge battery successfully. Now it sounds like I might also need a 30a controller and maybe it should be an mppt instead of pwm ? The total amps I would draw on this system if everything was running ( maxxfan-6-7 amps, on demand water pump 3 amps, and small led lights 1.5 total amps) would be appx 10-12 amps. I use the fan in summer only. I live in NM, so sunlight is no problem. Any insight as to just using 2 100w panels instead of 3 and keeping my 20a pwm controller ? Or, should I bite the bullet and buy 2 more panels and a new controller? All this because I thought I would save $ long term by switching to Lifepo4. ( should have done more research ! )
Thanks for any suggestions anyone might have….
