Saabpilot
Thanks Will for the excellent video on battery longevity. I realised that I have a problem.
I am about to Install 125ah LiFePo4 into my new Ford Ranger using a Projecta Lithium DC-DC charger.
Part of the set up is a solar blanket but for the most part, the alternator (connected to the Projecta) will hold the battery at full change.
So the battery will set there for months on end at 100%...sometimes in a hot car.
Yes, the charger is “5-stage” designed for Lithium and the Battery has a BMS on-board, but its still going to hold the charge at 100% most of the time because it will get very little use.
What I would like to do is limit the battery upper charge level (Say 75%) with the ability to restore to 100% when required.. (ie a camping trip running a fridge).
Does this make sense? Following up with the supplier the reaction was pretty dismissive... basically, you don’t need to do that.. the DC-DC Charger will look after the battery.
I have some thoughts on how this could be done but I would sure appreciate some advice!
Love your book... Highly recommended.
