bitrate001
Hi and thank you for an excellent forum!
I have a 200 Ah LiFEPO4 battery with a built in jdb BMS (JBD-SP04S034-L4S-200A). The battery powers from a 170W solar cell through a Victron BlueSolar MPPT 75/15.
The loads on the battery are usually low 2-5A. Occasionally 10-15A when using 230V AC equipment through a Victron Phoenix Inverter 12/500.
Now to the problem. I have been using this setup for around a year now and at 3 times the battery has gone from 90-100% capacity to zero in a few hours without any load at all. At first I thought it was temperature related (first time it was around -15 C) but it have happened two times after that in 15-20 C.
I have opened the battery and checked for loose or corroded wiring but did'nt find any (as far as I can tell that is).
Attached pics shows current load vs individual cell voltages at one of the outages.
Any thaughts on why this is happening?
Best Regards Håkan
![battdata.png battdata.png](https://diysolarforum.com/data/attachments/224/224946-98012790f383c14988af6eb3b2b823e9.jpg)
Best Regards Håkan
