hahahaa no I like trees. I got about 100ft x 40 ft area that I can put panels with no obstruction. Along the north side of the property. I just had no idea this tree would reach so far.. Now I know my best spot though
lol I did take down the largest tree cuz it was half dead. Got some others going mostly fruitTrees are great, but they've pretty much done the bulk of their duty removing carbon from the environment. Cut 'em down and plant new ones to suck up that carbon...
Recently? I read about the firmware upgrades (before buying them) and the bugs were from early this year but mine is only 2 months old or soIf you have EG4's you should download the tool and upgrade the firmware on your batteries. It fixes a number of issues, top-balancing being one of them.
I've upgraded my firmware in the last 2 months. The software will tell you what release you are on. Worst case is you find out they shipped you batteries with the latest and greatest firmware. Doubtful but possible.Recently? I read about the firmware upgrades (before buying them) and the bugs were from early this year but mine is only 2 months old or so
pretty sure it came with that cable.. or at least something did, I have one I haven't usedEG4® LifePower4 | 48V 100AH Lithium Iron Phosphate Battery - EG4 Electronics
EG4 Electronicseg4electronics.com
Scroll down get the firmware and BMS test utility. Assuming you have a USB to RS-485 cable for the PC.
Same as a motherboard. Once you have a working configuration for manufacture that is what you build. Changing firmware requires a QA cycle that costs money.Oh figured it was automated to newest firmware on assembly line like stuff usually is hahah rip
Pretty simple cable. Any CH340/RS-485 adapter had for < $10 amazon/ebay and an old ethernet cord will do fine. I have another post with the wire-out.pretty sure it came with that cable.. or at least something did, I have one I haven't used
Nope, I have an old Win7 laptop I used for automotive cruft b4 the EV's, worked fine on it. I run KDE Plasma on Bullseye/Bookworm everywhere. Gnome utilities like ARK use stuff from the default gnome themes, but rounded corners and soft-contrasts are not my goto thing in desktops.Does the software actually run on linux? looks like you have old gnome 2 UI stuff.. cinnamon or mate DE?
