I am upgrading my current system which is 30a pull behind camper with 2 lead acid batt. I have a basic pwm charge controller hooked up to the batteries and a plug that I hook up a 200 watt suitcase to when boondocking. I will put in 200ah lifepro4 and would like to add in a cutoff switch on positive side then run into fuse then a bus bar. on neg side want to run into smart shunt and into bus bar then into a renogy 20a mppt charge controller I will run the plug into charge controler so i can continue to hook up my panels that way. what I am having a hard time figuring out what gauge to run from batt into the shut off/ fuse shunt and bus bars. my panels currently run 10awg which I believe is more that enough and I think is the largest size that will work with the controller all the runs should be pretty short as I am doing this all in a small area i want plenty of wire but not so large that it becomes difficult to use I've watched you tube and read stuff I seem to just be making myself more confused
