timselectric
- Feb 5, 2022
- 19,792
Backwardsbatteries are connected to load, inverters to line like I have it wired I hope.
But at battery voltage, it's not as critical in my opinion.Backwards
As long as they will protect the circuit I'll leave it this way. Huge pain in the ass otherwise to move them but if I have to.......But at battery voltage, it's not as critical in my opinion.
Above 100 volts, I would be more critical about it.
A 58v arc isn't that hard to extinguish. Personally I wouldn't worry about it.As long as they will protect the circuit I'll leave it this way. Huge pain in the ass otherwise to move them but if I have to.......
They have different lug connection points top to bottom and extremely tight fit but are doable using different lugs.Can't you just rotate the breaker?
With how many amps behind it?A 58v arc isn't that hard to extinguish. Personally I wouldn't worry about it.
No more than the breaker is rated for. Because that's when it will trip.With how many amps behind it?
