So if it is not going to be used but 50 times you are saying it can be discharged to only 10% of the charge left?
I'm saying check the manufactures datasheets.
But overall sure! It's not a matter of
personal or
battery safety; it's about battery
economics and
longevity. A lead acid won't explode even if you drain it dry; all that draining it to a low depth of discharge does is to dramatically shorten it's possible life span. The reason you typically see 45 to 60% DoD for lead is that is usually where the best economics lie for the battery; but that might not be a good assumption for your usage. As members like
@Deno have reported and from manufacturer datasheets you can see Lead can have a good number of cycles.
But the real impact of what I'm saying is understanding how many charge cycles you want out of a battery will enable you to understand the best DoD for you, and allow you to compare different batteries at different costs in an apples-to-apples way.
Let's work an example. Say you want to cycle a battery everyday for 10 years; you need 3,650 cycles. Battery A costs $68.50 and has 500 cycles at 65% DoD. Battery B costs $1,000 and has 10,000 cycles at 90% DoD. Which is right for you?
Assuming the full DoD everyday, you need about two As for one B. Since 10,000 > 3650 you'd only ever need 1 so buying battery B will cost $1000.
For Battery A, to get 3,650 cycles at the DoD you'd need 2x3650/500x$68.50 = $1000. So, in this case the price is the same.
As an exercise, which is better if Battery B gets 1000 cycles at 45% DoD? Which is better if you only need 50 cycles?
Other factors:
- The time value of money. One Battery A would last over a year, the money you didn't spend on Battery B can be making you money. Or, if you can't afford battery B, buying a Battery A now would hold you for a year so you could save up for it - and in that time Battery B's price might come down.
- In addition to cycles being greatly affected by DoD, the actual power from lead chemistry depends on the current draw rate and ambient temperature, see the Battery FAQ .
- Weight, lead acid batteries are heavier. Not much savings if you hurt your back or crack your floor.
- Battery maintenance/venting, FLAs in particular need a lot of care. (seriously, don't buy FLAs, don't even take them for free )
- Low Temperature operation
- Extra work in replacing more batteries (remember, they're heavy).
- You generally get cash back for turning in lead batteries, you might have to pay to dispose of lithium.
