The current setup:
I have 3x 340W panels each going through a Victron 100/30 MPPT and 25A breaker, then directly onto an AGM battery. Each MPPT is connected to a different AGM battery. The AGMs are in parallel and connected to thick wires which appear to travel to the other hull of the catamaran and into the switchboard etc.
The AGMs no longer hold their charge, so while it is light outside I have power, but as soon as it gets dark I turn all loads off (and my headtorch comes on)
The only high-draw item currently is a Dessalator 60L 12V Watermaker, which uses about 38A (and in winter can be run by solar alone close to noon on a blue sky day), and is on the same hull as the switchboard and opposite hull to the batteries.
The new arrivals:
12x 3.2V 280Ah EVE Grade A cells, intended for use as a 3P4S 12V 780Ah “house battery” for the catamaran
8x 3.2V 105Ah EVE Grade A cells, intended for use as a 2P4S 12V 210Ah “dinghy battery” to power a 768W trolling motor on the dinghy (I’m already using this trolling motor but with an 80Ah AGM)
1x JBD 80A BMS, intended for use with the new dinghy battery
1x Nice-Power 30V/10A max bench top charger
What I don’t have yet is the permanent BMS solution for the house battery, but I figure initially I can use the JBD I have, at least until I’m ready to install a Multiplus and starting using a 1500W cooker.
The plan:
I’ve built a compression setup for the house battery, and I’m ready to top balance. The issue is I’m still away from shore power, so I need to figure out the best way to do this using my current solar setup.
I would like to use my MPPT to get the cells (in 3P4S config with BMS attached ) charged to a safe high level, before reconfiguring into 12P for last bit of top balancing using bench top charger. I plan to only attach one of my 340W solar panels for this.
My question: is this plan feasible?
If so, what settings should I put into the Victron MPPT and the JBD BMS to make this as safe as possible? e.g. what voltage should I be charging at?
Should I be adding anything else e.g. fuses into the setup before I start?
As a reminder, if I don’t buy anything else, it would be 340W solar —> 25A breaker —> Victron 100/30 MPPT —>
(+) —> Positive of 3P4S battery
(-) —> 50cm 25mm2 cable —> C- of JBD 80A BMS, B- of BMS —> 50cm of 25mm2 cable—>Negative of 3P4S battery
(all balance leads also attached)
The next stage:
I also have to decide what the best permanent BMS setup is for this, as I also plan to install a Multiplus II 3000 (2400VA), which will require something much more capable than an 80A. I was thinking a REC ABMS, but having recently seen this https://community.victronenergy.com...ed-bms-av.html?page=3&pageSize=15&sort=oldest, I’m wondering if for less price I could get three JBDs instead of the REC ABMS.
This should allow me to make three individual 1P4S batteries and monitor each cell individually instead of each block of 3, and presumably change setting and monitor the BMS which needing the expensive extra REC BMS wifi module - what am I missing?
Would love to hear people’s thoughts, any questions, and anything I might’ve missed in my thinking - thanks!
The new arrivals:
The plan:
The next stage:
