Load Sharing and Sharing of Battery Charging Burden In Victron
RotEvery
On my Sorotec VM II inverter system there's a PAL setting that makes the Solar and Grid to share the load and share the battery charging burden during the day. Is there such a simple way to achieve this in Victron systems? Not sure how to do this on my Quattro/RS 450/100/Cerbo GX/LFP Batteries system.
You may be able to use VS to simply toggle AC input based on battery voltage.
I've played around with VS and found out it doesn't quite work the way the PAL setting works in Sorotec. Victron should consider having a simple setting that achieves same purpose as the PAL setting.
