Hello, firstly I am new to all forums but cannot find the answer to my questions from trades people. I am English and live in France. I have four solar rotators complete with ten 400 watt panels on each. I was using two 8 kwh inverters in parallel (c/w inbuilt MPPT) and six Pylontech US3000c batteries. I had problems from day one with communication problems, error messages on batteries and inverters that got worse and worse over several months. The inverters would not speak to the dongles either. Eventually the electrician decided to disconnect the inverters because they were constantly tripping the house mains. The inverter company seemed totally lost and despite answering every question asked providing the data requested and extensive photographs they were at a loss. For clarity we did have communication between the batteries and the inverters however the panel kept changing the error message numbers. We then decided to change to a Victron Multiplus - 11 230 v 15 200 100 kwh + four MPPT's and various Lynx and Cerbo GX , Cerbo touch 50 and Cerbo S GX. All good so far.
We have five unused SOK 5kwh batteries 48 volt 100 ah. I have seen information on Current sharing but have not seen anyone actually give a breakdown of of how to do this. Now to the questions please. Firstly can I connect the mains power (230 volts ac) to a second independent electrical fuse box and then a separate inverter with these batteries and use more solar panels so that I have two complete solar systems. What security systems would need to be designed in? Would the two AC systems work together without issues. Secondly, can I connect the batteries safely I.E. Pylontech in one stack and SOK in another stack and share the solar panels. Would I need different DC fusing? What safeguards would need to be installed. The existing solar panels charge the Pylontech batteries on sunny days in around three hours so capacity is great. My only issue is that I need more battery power.
I understand that I am a newbie but please do not just shoot me down without explanation. I see many youtubers regularly connecting multiple batteries etc to their systems without any problems. Thank you in advance in anticipation of you help and please....kindness.
