Some people might have a concern about 2 larger loads turning on at the same time on an inverter...it might be pushing the rating somewhat..
Is there an electronic switch people use that is wired up with the 2 loads passing thru ,that will only allow one load to run and then when its finished(like a well pump)
it will enable the other load...but not both at the same time...?
