silverstone
- May 3, 2022
- 1,041
I hope some of you might know the name of such a device, assuming it exists.
What I am looking for is some kind of "shunt trip unit" Relay that, when energized (say 24VDC or 230VAC) "latches" and disconnects power (contacts configuration change from COM-NO to COM-NC).
I would just like a "Relay" that, when energized, trip its associated circuit, REQUIRING a MANUAL RESET of some sorts (preferrably just a lever). Basically without a breaker.
Bistable relays are close, but the ones with dual coil are expensive and, realistically, SET and RESET coils can be interchanged most of the time. This means that in case of a software bug, nothing prevents the system from being re-energized.
Multifunction Timer Relay are also close, and one could say that with a big enough delay after a pulse, it's ALMOST a manual reset (e.g. delay of the order of DAYS after a pulse is applied).
Shunt trip unit + breaker powering some kind of intermediate circuit that is then fed to the application, would be yet another alternative. But since SEVERAL circuits are needed, this becomes quickly expensive and large in terms of surface area.
I also considered buying some cheap chinese trip units such as CHINT off Aliexpress for instance:
Do you know if such a "single shot" triggered device exist and what name it has ?
