Oh wow. Maybe I'll not go with RV stuff.15' of exhaust tubing may have been at least part of the cause of the carbon issues you had with the diesel heater. Another cause is when people start messing with trying to run them on "low". Diesel is a very challenging fuel to burn well and generally speaking they want to be run full time and on high. Running them on low and turning them on and off constantly is a recipe for carbon.
Exactly. Starts up at like 12a & then runs on 5a or somethng. Turns on & off depending on outside temp. Very hard to calculate.I'm also considering an LP furnace and having a hard time with what the solar requirement will be for the blower. Looking a spec sheets for several the electrical connection is 120V single phase with max breaker of 15amp.
You can go as long as you want to but you need to be aware of pressure drop. I had made the possibly bad assumption that you had used the style of exhaust tubing that was supplied with the heaters. Using longer runs of that is problematic.Oh wow. Maybe I'll not go with RV stuff.
My build is kinda funky as its a remodel of a shack & shipping containers. The containers are the core. A long way to vent. Like to just vent out the roof.
That & running on low 24/7 for months seams to be the issue. Guy that sold me it also sold me extra long exhaust pipe & never said anything. I thought I was a fing genies using all that waste heat..... So you need to waste heat to keep the machine working correctly.... Brilliant engineering...You can go as long as you want to but you need to be aware of pressure drop. I had made the possibly bad assumption that you had used the style of exhaust tubing that was supplied with the heaters. Using longer runs of that is problematic.
Never had to take it apart in 16 years? This unit I have looks so poorly designed/ built, I cant see it lasting 16 months. I bought the "best" I could get.... Ah capitalism strikes again. Just keep building them cheaper & cheaper, 16 years later they don't last a year. I followed the directions. There was no exhaust length maximum. The seller didn't even know that. Even if they are not garbage, if the directions are not correct then you just have to be lucky.My Webasto is a 5kw unit water heater that came out of a Land Rover, is 16 years old, and it's been running an under floor heating system for the past 8 years with no problems.
Please try to take this as constructive.Bought a used Buddy to make it threw tell I can install a furnace. Work a few hours & died on the freezing night.... While it was working I had a sore throat & didn't feel good. So they are complete brain cell killing garbage. I am so sick of all this crap. Diesel heater dies in months & people want to make them sound good by throwing around crazy long years theirs "worked". But no answer on how many times you gotta take it apart. Seams like anything made for RVs or off grid is cheap disposable crap &/or overly needy of ridiculous maintenance. Probably why most people off grid are broke. You buy a furnace for a house that only lasted 4 years? My 2015 very nice RVs furnace died in under 5 years.
I just want a normal furnace that I install once & change a filter every 6 months that is the model that uses the least power. No one knows....
We are ruining our ability to live comfortably on earth with all this disposable crap....
I followed the directions, the English part. How would someone know that info? Cant run it on low, has to waste heat to work, diesel stinks. The problem here is they are built for vehicles & people that know nothing are selling them for tiny homes. They are not a good option for a tiny home in a area with propane.You have said and acknowledged that you had not installed the diesel heater correctly. It is almost a dead certainty the way it was installed caused your issues with carbon fouling.
They are good, until people start trying to turn them down, mess with settings and install them incorrectly. Then there are always issues.
Good point. But its a heater, with Chinese directions. I would have never guessed a heater would require so much TLC. I'll change the heaters air filter. Thats about all the time I have in my life to mess with a heater/furnace. I have way better things to do & the $ to not buy crap. But people are motivated by profit. So they sell you bs, tell you what ever it takes to make that sale.... I never should have been sold a diesel heater with 30' of exhaust pipe. But that was a good extra sale for the profit for some know nothing capitalpath.Have you heard the expression "Its not the plane, its the pilot." Most issues are operator error. If you take the time to learn how to use the tools correctly, they almost always not only simply work but work well, even the chinese ones that cost 1/10 what a wabasto/espar.
"Dirty propane"..... Didn't even know that was a thing....Yes the buddy heaters are not good , I would use one of the Williams wall-mounted heaters .
They work really good , easy on fuel , plenty of heat , you can run it off a thermostat
Dosent use power , at least mine don’t .
ps if you get dirty propane the buddy will clog up and not work .
They sell a filter that go’s on the heater to prevent this
Yup, just like a normal furnace. I guess "forced air" would be the name.You are saying a lp furnace that "uses the least power". I'm assuming you mean electric power?
Well if you had not bought a cheap knock off you would have known all the info. Buy Espar the new ones are brushless motors and will last year's. 24mm exhaust 2meters max. Go to 30mm exhaust and run 4 meters. If you have all this money to spend then spend on quality and buy from a dealer that knows.I followed the directions, the English part. How would someone know that info? Cant run it on low, has to waste heat to work, diesel stinks. The problem here is they are built for vehicles & people that know nothing are selling them for tiny homes. They are not a good option for a tiny home in a area with propane.
The ticking unit. Ticking would be way better than freezing.
Maybe I should move somewhere thats not freezing 8 months a year. I don't mind the cold but I've almost died twice now due to trying have power & not freeze.
Here is an example. Had I posted here "thinking about diesel heater, what should I know?" Would I have got the correct info? When I asked "what is this" & provided a photo of a continues duty solenoid. I got the wrong answer, bought, installed & fried the wrong part due to someone that sounded so knowledgeable being wrong.
At the time I watched 4-5 diesel heater installation videos. Not 1 said anything about exhaust length or that running on low is bad. The fact someone would need to read this thread to find that out proves my point. I wish past me could come to the future & read this before buying that heater in the 1st place.
No idea there was name brand. Typical with these garbage systems the world is run by. The crap fills the search. Liars. I was told I was buying the best one.Then why by chinese? Spend that $ on an espar/wabasto that will come with directions you can read and actual tech support that will answer your questions. Yes, I know your not interested in diesel anymore.
That is super interesting. Do you think that can be used to find the lowest electric consumer?Fact: if you want high efficiency (fuel) then you are going to be using more electricity. You cant get away from that
Thats the plan but again... Was sold a 46.8v battery as a 48v battery by Big Battery so I am just going to use that until I have a climate controlled area for to build my own. Climate controlled by a furnace...Draws to much power? Spend some of that $ on a bit more solar panel battery.
A few reasons. If I pay people to do everything I wont have enough $ to do everything & I am not doing permits.Just hire the job out if you actually have the money and leave it up to someone that knows what they are doing.
I'll make sure to tell past me that.Well if you had not bought a cheap knock off you would have known all the info. Buy Espar the new ones are brushless motors and will last year's. 24mm exhaust 2meters max. Go to 30mm exhaust and run 4 meters. If you have all this money to spend then spend on quality and buy from a dealer that knows
The lowest electric consumer will be the one that draws NO electricity. They will be natural draft and have no circulation fan like that williams unit on page 1. They will all be 70ish% efficient as they require hot combustion gasses to produce the draft through both the chimney and the convection current to heat the building. This is your lowest consumer of electricity.That is super interesting. Do you think that can be used to find the lowest electric consumer?
I would have already got one but the ticking worries me. I've given up all my hopes & dreams except for a good nights sleep. My rooms I need to keep warm are 2x 20' shipping containers that are not connected side by side. If I have a forced air unit in one container ducked to the other, it will keep the unit its in from freezing also. Thats why I was not concerned about the efficiency. I'm pretty much just concerned electric consumptionThe lowest electric consumer will be the one that draws NO electricity. They will be natural draft and have no circulation fan like that williams unit on page 1. They will all be 70ish% efficient as they require hot combustion gasses to produce the draft through both the chimney and the convection current to heat the building. This is your lowest consumer of electricity.
