ebmjohnson
- Feb 12, 2020
- 4
I recently bought four 24 volt 200 watt Rich Solar Panels to put on my travel trailer. When I first got them I tested each panel and got between 70 - 85 watts per panel which was horrible but it was hazy cloudy. I didn't have a chance to test them again in full sunlight before I installed them. I should have known it was too low when I tested my 200 watt Renogy eclipse suitcase on the same day and I got 160 watts. In my mind I justified it by saying the Renogy eclipse are excellent panels and perform well in cloudy/low light situations. Now they are on my travel trailer roof and I am getting 360 watts on a sunny day (albeit winter sun angle). I have it setup in a 2s2p configuration and I can't for the life of me figure out what is going on. I confirmed I am getting the correct voltage from each panel and I confirmed each series connection has the correct voltage and I was getting ~180 watts per series panel. I reached out to Rich Solar and they wanted pictures of my setup which I sent but I have not heard back yet (it has been a week) but I understand that it is the holidays and responses can be slower.
I did test on a victron charge controller and I am currently using it on my EcoFlow Delta Pro and getting the same results on both. I am wondering if I am just missing something simple as these are standard glass panels and while I am not expecting 800 watts from the setup I was expecting 600 - 700. Are there other ways I could test if I just got bad panels? Since they are installed now it will make it extremely difficult to test each panel again but I am willing to do the extra work if I can learn new ways to test panels! I can test the two groups of series panels easily enough.
Thanks in advance for any direction you can provide.
