Mike.Indiana
- Aug 11, 2021
- 23
Batteries are charging by utility even though I have option 16 set to "solar only". This is causing me to waste excess solar energy during the day that should be battery stored because the utility has already charged the batteries from the overnight discharge/charge cycle. It appears that option 16 does nothing. Anyone else notice this? My inverters are nearly 3 years old. Ian at watts24/7 said he hadnt heard of this problem but with the age of my units he thought a software update may fix the problem. Im hesitant to update the firmware not knowing if it will fix the problem and potentially causing more problems.
Any suggestions out there?
TIA
TIA
