LVX 6048 shows 180-250v but only 50-80w for PV array
veearnis
USA
I have a LVX 6048 connected to a pv array through a 247watts 8/2 combiner box.
I have two strings of 4, 445w 41.9v panels for a total of 3570w with 335v.
First issue, at the main breaker, the combiner box only shows 250v max on a multimeter. This is also what I getting on the pv lugs of the 6048.
Second issue, LVX 6048 250v max BUT ONLY 50-80w no matter if load/no load or battery charged, etc.
I emailed 247watt support and they said fuse blow. I changed all the fuses, same issues. Now they do not respond to questions.
I also changed out the LVX 6048 with another…same issues.
Any ideas will most certainly be appreciated this is a frustrating issue.
The third string has been decommissioned as I didn’t want volts going too high.
7ECC1AAF-0C6C-4D00-92CA-D3B128FE7DCF.jpeg7ECC1AAF-0C6C-4D00-92CA-D3B128FE7DCF.jpeg2AA5519E-FA82-4B1C-88A7-80D9DA85DA6D.jpegEA2605A1-1930-418A-87EB-DBDBB8B21708.jpegE9119D25-867B-4BB6-B8BF-34506AC20FB6.jpeg7AC2759D-436A-4E04-89DD-BEFAF7DCEAEC.jpeg
From the pictures, it looks like there are 3 strings going into the combiner box
Each string of four 41.9V panels should be 41.9 x 4 = 167.6V But the measured voltage is 250V. (150V is in the range I would expect.)
To get 335V from 41.9V panels would require one string of 8 panels.
SO.... I am confused. Could you tell us a bit more about your panel layout?
View attachment 152679View attachment 152679View attachment 152680View attachment 152681View attachment 152682View attachment 152683
Have you figured this out? I have exact same issue. Plenty PV voltage, and super low wattage available on screen. I have (6) 300 watt LG panels connected in series and now showing 230v/45watts. I've tried to reach out to MPP Solar and nothing has fixed. They are slower to respond, but I don't want to get stuck owning a $1200 wall piece that was meant to be used without any battery connected. Wtf.
