newbostonconst
- Sep 24, 2019
- 1,005
In parallel setups the voltage is going to be the same across all batteries (provided no bad connections, or shorted cells) Batteries are damaged when the voltage gets to high or to low but the Op's batteries have a BMS to protect against that. Resistance doesn't mater because they are all at the same voltage, if the voltage is the same they will all hit the knee in the curve the same and thus be nearly charged or discharged all together. If there is a weak battery and its voltage wants to drop it can't because it is tied to the others and they will supply the power.
Only situation that could be(but not likely) is in high power drain installs where the battery is drained in under an hour, but even in this situation there is a BMS in the OP's batteries.
How many parallel cells are in Tesla's?
