Battery with more than 15v
Dexron
Hello everyone.
After installing my 12v 4s battery, it was charged to 14.6v, it has been stopped for a while and when I go to use it it reads more than 15v, when connecting it to consumers the voltage rises to 15.80v.
Does anyone know what this is and how I can fix it?
Thank you.
Después de descargarse, la batería tiene 13,37 V, cada celda tiene aproximadamente 3,31 V. pero el BMS solo tiene un voltaje de salida de 3'24v.
Es un Daly 250A.
¿Alguien sabe qué podría estar causándolo?
Es un Daly 250A.
I'm not sure if the translation is correct.
Did you fully discharge the battery?
No.
the bms output reads less than 3.5v
Is there a way to check its operation?
It is a daly without bluetooth, 12v 4s and 250a
If it's reading less than 3.5v per cell then it's not fully charged. Throw it on the charger and top it up. The BMS should stop charging when the first cell hits 3.7v if you have that programmed correctly. When the battery finishes charging, don't be surprised if it stops at 14.5 or 14.6 or so, then sits and settles down to 14v or so as everything settles out.
