Thank you very much, I'll order it now.One of these will take 18 hours to charge your 2x280Ah battery bank from 0% to 100%. But it’s better than what you have now, which is too little charging.
Yes, you can just hook it up to your bank. Positive wire to positive on battery one. Negative wire to negative on battery two.
You also will need some wire. 4mm^2 at a minimum, but thicker is better. Iirc, I used 8mm^2 for mine. You also need ring terminals that match your battery and the wire. The charger comes only with the cord to plug into an AC outlet.
Before then, you can download the Victron Connect app to your phone. It has a demo mode where you can see and adjust all the settings. If you want just plug and play, just pick the Lifepo4 preset, it will do fine to start with.
When you get the charger and hook it to your battery and plug it in to the outlet, you’ll then see it as an actual device when you open Victron Connect.
Cheers
