As the thread title states, I have a Magnum MS4448PAE that is causing nuisance trips with arc fault interrupters on the same leg (L1). For example if I have an arc fault breaker in slot #2 on my panel, and a standard breaker in slot #4 on the panel and a toaster oven connected to breaker #4, after running the toaster oven for a minute or two, AFI breaker #2 will trip (even with nothing attached to that breaker). All the breakers are Eaton.
By moving the resistive load to L2, this problem goes away. But that isn't a long term solution, as resistive loads will be plugged in in the future to other circuits without much thought as to what leg of the panel is being used.
I'm not sure if the funny business happening around 0 volts is causing it, but that's what I see when I put an oscilloscope on the inverter.
Has anyone else realized this problem?
I am thinking of upgrading to a different inverter, as this one promised frequency shifting for ac coupled solar, but its frequency shift voltage set points are non adjustable and aren't compatible with LFP batteries.
![SDS00007.jpg SDS00007.jpg](https://diysolarforum.com/data/attachments/97/97781-a8de1556f857ab05d0e0fb2fcd99b7ef.jpg)
