Coydon
I'm feeling a bit 'off-balance' plowing through all of the opinions on top balancing from the last few years. In fact I used up my data allotment for the month so could use more guidance. I don't mind spending some time to learn and do things to make a better battery, but don't want to buy special use equipment (or do nothing for a week while it ships). What is the best I can do to get my 24V system up and running ASAP without causing long term degradation of cells?
I have had 8 Ganfeng 270s sitting around here for a year. One of the cells was leaking out of the box and 18650 sent a replacement immediately. Now I'm looking at the cells and they measure in order (starting with the replacement):
3.32
3.26
3.28
3.28
3.24
3.27
3.27
3.28
I think I read that more than .02V variance is significant when assembling the battery, so these have gone pretty out of whack. By the labels 18650 put on them, the originals were matched pretty close (between 279 and 281), but the replacement was a 289. I don't need max capacity right now, just something that works, even 50% capacity would be fine for a while.
For chargers, I have my 30A solar charger currently in use on a 12V 225Ah FLA system with a 600W inverter. I have 3 12V chargers for starter batteries. Two of them are for Lead Acid batteries, and one is an Optimate for my LFPs. If I connect my cells into 2 12V configurations and plugged them into the Optimate, would that be the fastest way to bring them to a higher SOC? Would the result be balanced enough that I could assemble the battery and let the BMS work it out from there over time?
If the vehicle batteries wouldn't work, anything else I might have around from other electrical junk that could do better? I have a bunch of old computer stuff and a couple of cheap buck converters, but they are only rated to 3A.
3.32
3.26
3.28
3.28
3.24
3.27
3.27
3.28
