DIYrich
Solar Wizard
Another thread got me thinking... the reason the Sol-Ark 15k is advertised as 12k off batteries is because it is limited to 275 amps off the battery, and they use a conservative 48v for the battery.
Instead of 16 cells, if you put 18 cells in series, you can deliver 15k and stay within the 63v limit for the battery input.
Any thoughts?
Also, with a rack battery, can I put a two 100 Amp cells in series with the rack to boost it up to 18 cells? I would run the battery as open loop (by voltage).
Any thoughts?
