That vendor deals with consumers and consumer devices. Consumer get confused when you tell them that for most recycled-lead agm's (which these are, unlike pure-lead), the maximum current is typically between 0.25 to 0.3C.
Which for a 35ah agm, a max of 10.5A at 0.3C.
But why the 15A max rating? This is simply to try and accomodate consumers and extend the *possible* range of chargers they buy off the shelf.
What will happen in the real world, is that even tough 15A is too high on paper, because nearly ALL modern consumer chargers are of the cc/cv type, the cv will be reached quicker than normal, and the battery will be in the cv mode (the so-called taper-current) earlier and longer. So no major damage.
But it does allow the unknowledgeable consumer the ability to use a charger - no higher than 15A - they may have off the shelf and make the battery sale.
YOU - however, being more knowledgeable now, will limit your charger / controller choice to something no larger than 10.5A for a more efficient charge. (stay between 0.25 to 0.3C max)
Double that for two in parallel as the max. Or triple it for 3 in parallel and so forth - assuming they are well balanced - but that's a different subject.
