Yep you mean this below , have you seen all the Cheap Charlie shite on Ebay, no danger of finding the genuine article. BTW, assume you dont mean those "solder ring type" which you use a hot air gun to solder the splice together. Some very iffy results reported by this dodgy kit - you cant see if the solder has wetted properly and we know how soldering sometimes doesnt work properly.
Ive got some of those butt splice ferrules from a reputable source - thick wall centre wire stop etc. Trouble is that you need a hydraulic crimp tool to get full force (16t) and the precision anvil. A professional kit with purpose made ferrules is ca $500 - but it is Mil Spec quality.
Are you just trolling now or did you intend to post this thread in the danger zone?Just when you thought your day couldnt get any worse (Im not referring to the Dem POTUS in waiting guys) herewith pix of Mk ll to make your day (Warning could elevate your oil pressure). See how the cone seat flares the wire cores ready for compression.
This is an an 3/16" oil pipe flared coupling from your local auto shop. (more work needed) but it <1$. I daresay you could load it with Si grease and cover it in heat shrink. Just the thing for OG Preppers . Whats not to like. Good for 50A? Armchairs, you may now sh*t on me from a dizzy height. Mk lll in preparation but you can have too much excitement in one day.
This is a classic example of what happened to people over indulge themselves on MSG Rich Foods:Are you just trolling now or did you intend to post this thread in the danger zone?
A vain hope it might inspire some surgical thought to mechanically connecting high current electrical wires rather than using mickey mouse sliding pin and socket methods which is copied and spread around the market by Cheap Charlie (as the many YT vids can show). Spare a thought for the hapless consumer who has an installation fitted up with the fake MC4s. Arc faults may take some time to show up - and then a roof fire gets going - what do you do then?Are you just trolling now
You are just not on message, pay attention! Brass has a rho of ca 3.5x Copper. We all know that. You just make the conductive path thicker. Brass has been used for over a century in switchgear. Its mechanical properties make it much more suitable for mass production and the bulk material is also much cheaper (compare a copper busbar to a brass one)Plus does this table not sum up the reason why we're not using brass to make our electrical connections
Your preach-n to the choir i've been making reliable electrical connections longer and you've been drawing airA vain hope it might inspire some surgical thought to mechanically connecting high current electrical wires rather than using mickey mouse sliding pin and socket methods which is copied and spread around the market by Cheap Charlie (as the many YT vids can show). Spare a thought for the hapless consumer who has an installation fitted up with the fake MC4s. Arc faults may take some time to show up - and then a roof fire gets going - what do you do then?
The flared coupling is a very traditional reliable method used in hydraulics, long before compression fittings. Why not use it to connect solar cables? The design may need some fettling but still follow the KISS principle.
What I like is that it is so simple and basic that Cheap Charlie wont bother to make fakes. So WYSIWYG
Mk l is also in the same mould but I am making up Mk 1.1 that is even more attractive for blowing away the Armchairs.
I give up.A vain hope it might inspire some surgical thought to mechanically connecting high current electrical wires rather than using mickey mouse sliding pin and socket methods which is copied and spread around the market by Cheap Charlie (as the many YT vids can show). Spare a thought for the hapless consumer who has an installation fitted up with the fake MC4s. Arc faults may take some time to show up - and then a roof fire gets going - what do you do then?
That's just great.Or folks could spend a few buks each and get the real deal stabuli connectors or other quality ones and not worry about it for 20 years. This is instead of the knock-offs that are sold by the dozen.
Go back to your garage and sing this song until your head explodes, then start again.
Careful don't give any ideasI give up.
Go work on upgrading all the wall sockets in your house that have been using sliding connectors, while your at it reinvent all the fuse and relay connections in your vehicle, don't forget the cigarette lighter.
