Hillseeker
- Feb 3, 2021
- 1
Will your work is the best, I really respect you and your work.
We work with Variable Frequency Drives to control the speed of AC motors for industry and HVAC systems.
We use Fluke Scope Meters that prove to be an excellent tool for seeing the output of inverters.
I don't know if you have tried this. We can tell the "health" of the VFD by looking at the output waveform during maintenance.
It is great to be able to see the output voltage compared to the true sinusoidal input of the AC source.
I am sure you would really like adding this to your break down tests of new products.
The shape of the output waveform derived from turning the IGBTs or Fets on and off supper fast to simulate an ac waveform.
Over the 40 + years of servicing electronic motor controls I found 20 years ago the scope meter to be the most valuable tool that lets you see what inverter is putting out. As components start failing you can see the waveform start to deteriorate and loose definition.
It would be a great addition to your tests, full loads and load surges can be compared product to product.
I think you will geek out on it like I have over the years.
I don't know if you have a scope or not. It is great to be able to see the voltage and current sinewaves.
I would like to see difference between the high and low frequency inverters.
We have used the Fluke 43B not made anymore but can be found for less than $1K used.
Let me know your feedback.
Thanks for all you do Will
Pete
Pete
