After reading many threads about not using polarized breakers as PV disconnects, I am still wondering about this Midnight 2pp breaker if it should or could be used safely as OCP and Disconnect? I bought a 50A version thinking I could use it this way but then started reading bad things about using polarized breakers as PV disconnect. I realize the breaker I have is 600V so each side is only 300V my system is only Voc x1.56 142V.
This would be outside in a Midnight box and I realize it is not code compliant since it would in inside the box.
I want to know since this is a polarized breaker if it is safe or would it be safer to use disconnect IMO switch and then combiner box with OCP. System is Off Grid.
![2pp breaker.png 2pp breaker.png](https://diysolarforum.com/data/attachments/217/217408-b8fe71c3df9f225d1cab920cc5a8ea4f.jpg)
