Ohms_Cousin
- Nov 6, 2020
- 187
I posted this info in another thread but it was on the end of a long thread - so may well be missed by many. Reposting the info here so others get to see this info. I believe this small Hatz diesel genset to be very different to every other small genset I have seen.
This seems to be a nice Diesel battery charger.
Hatz (German and very old well respected company) single cylinder with a Hatz designed and built 56v 100 amp *PMG* attached to the flywheel of the engine. J1939 CAN bus equipped from the factory.
There is a 24v version if thats your voltage with 2 different 24v units available - 24v / 100 amps and they have a 24v version that has *TWO* inverters attached to the 3 phase output of the PMG to give 200 amps at 24v (1 x 100 amp + 1 x 100 amp attached to the one engine)
They also do a 115v unit and a 230v /13amp unit with the same PMG setup. That is, the one AC unit can do either 115v **OR** 230v by adjusting jumpers on the unit. From the data sheet............
......Voltage output (Factory Setting) Volt out nom.: 230/115 Volt AC. Selectable by mean of JMP1..... - Seems to be very versatile and something I have never seen or heard of before on a genset.
Choice of engines - the 1B30E which is 347cc and the bigger 1B50E which is 517cc. Diesel usage listed as 1.2L per hour at 3/4 load on the bigger 1B50E
Here......... https://www.auroragenerators.com/product-page/battery-charging-dc-generator a US based manufacturer uses the same Hatz 1B30E engine but uses a different approach to generating the 56vdc. I prefer the PMG method built by Hatz myself as there are no external parts or belts to maintain over time.
Note the diminutive size of the 56v 100amp PMG unit....
Dimensions (mm) - 357 x 440 x 480
net-weight (kg) - approx. 71
packing dimensions (mm) - 570 x 570 x 820
gross-weight (kg) - approx. 82
Seems like a nice solution.
75 Specification + Data PMAC-230-5-3,0 August 2022 .pdf673.1 KB · Views: 16
73 Specification + Data PMDC 28+56 Volt August 2022 .pdf725.8 KB · Views: 17
