Hi all, for background I'm in the UK and looking to add a grid tied system to my house. I have only fairly limited roofspace I can use for PV panels.
The main problem I have is that I can only fit 3x relatively small panels to my south facing roof. The only panels I can find that will fit are the Perlight Delta 295w. In contrast I can and plan to fit 10x Jinko Tiger Neo 430w panels to my west facing roof.
Clearly this gives me a problem with regard to inverter choice and sizing. The 3 panel string won't generate enough voltage to switch on the MPPT on every dual MPPT inverter I've looked at that's also big enough to run the 10x panels.
To complicate things, I'm thinking of a Hybrid inverter so I can add (Pylontech?) batteries in the relatively near future. I'm looking at the Sunsynk ECCO 5kW inverter.
I've been reading on here that I could wire 2x strings in parallel and that might get me over my problem. However, I think I might be misunderstanding the other threads on here. If I have 2x strings of roughly 90v, connected in parallel to 1x MPPT, then surely my voltage at the MPPT will still only be the higher of the 2 strings and still not enough to start up the MPPT (needs 125v)?
Anyone got any clever ideas or do I just need to accept I need 2 inverters?
If I went with 2x inverters, 1x hybrid and 1x pv only, presumably the batteries would only charge from the generation from the string connected to the hybrid inverter and not the string connected to the other inverter?
Would appreciate some expert guidance as it seems an unusual problem and starting to make my head hurt trying to find the correct solution!
Thanks
Thanks
